メインコンテンツにスキップ
Repair and disassembly guides for GE Microwave ovens.
349回答 すべてを表示
Replacing dead high voltage cap with similar of lower capacitance.
Hi,
The high voltage capacitor for my microwave oven has shorted. It is a 2100v, 86mfd capacitor.
I have a "spare" that is very similar: 2100v .76 mfd (so .76 instead of .86 mfd. Can I use it?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Without knowing more, I'd say not to use it. That particular rating may be required for the proper operation of the magnetron (the thing that generates the microwaves). GE should be able to get you the right part.
Best of luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I had been hoping for an informed reply. It turns out, as I learned since I posted the question, that the high voltage capacitor is part o fhe voltage doubling circuit between the high voltage transformer and the magnetron. If the capacitance is a bit low, it reduces the final voltage - it does not quite "double" - to the magnetron, which results in a small reduction in the power the magnetron delivers, but with zero risk to the circuitry.
さんによる
コメントを追加
回答を追加する
H Stahl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 137
