メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Home button works on login but not after
This is the first time I've come across this problem after repairing many iPhone 7s.
When the phone is locked you click on the home button and get taptic feedback. The touch ID works and you get access to the phone.
When the phone is unlocked the home button stops working. No taptic feedback at all.
The fact that it works when its unlocked means its not broken.
Has anyone else come across this problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I wonder if the taptic feedback you are getting when you unlock the phone is more related to successfully registering TouchID than to recognizing the "click" action. For example, if you could delete the stored fingerprints, the button may not recognize your finger push at all when locked. Clearly the button doesn't register your clicks afterwards.
This scenario happens when the IC (Turtle / U10) on the Home Button flex gets damaged. This is a common occurence (relatively speaking) when the button flex is transferred over to a new screen. The solder balls underneath the IC can crack and cause connection issues. This can be repaired via a micro-soldering repair.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
The plot thickens. I asked the user to update me throughout the weekend. After charging the phone for 30 minutes the home button started working again and then several hours later he reported that it stopped working again.
さんによる
This still points to a potential U10 issue on the HB flex.
さんによる
コメントを追加
回答を追加する
Alexander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 144
