メインコンテンツにスキップ
Released 2015 Model Number: POLSP01W
Why are there lines in my photos?
Everytime I print a picture with my snap, it comes out with weird lines through the picture. It hasn’t always been like this so I’m not sure what happened. I’ve tried used different packs of film, but the lines still showed up. I also tried cleaning inside of the Polaroid with a cotton swab like other people suggested but it didn’t work. Please help!An example of the lines
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It's likely caused by dirty heads or bad paper. Since ZINK is a thermal technology, it dpends on the thermal head being clean. This is also why the paper packs include a cleaning/calibration sheet.
Try a new pack of paper, which will rule out bad paper and dirty heads. Most ZINK printers dislike sudden paper changes (not a problem with dye sub), so use the current pack up to avoid sync problems. This may not be the case every time, but it's the norm with most ZINK printers. If this doesn't fix it, then the thermal head is bad.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
How could I fix the thermal head?
さんによる
The thermal head looks replaceable, but it likely requires a donor camera with a different issue to get one.
ZINK printers are targeted towards people who want a pocket size printer for social meetups, so repair isn't a priority.
さんによる
Mine started printing lines after an update. I updated because the colors were terrible. Now it's $%@! ruined.
さんによる
コメントを追加
回答を追加する
Kyleigh paige さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 45
今までの合計 10,229
