(Asus zenpad Z8s p00j) where can I find replacement screen?
I've look on eBay, Amazon, Google I can not seem to find parts for this specific model. Can anyone point me in the right direction ASUS ZENDPAD ZS8 P00J
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi ,
Just wondering if a Zenpad Z8s P00J is the same as a ZenPad Z8s ZT582KL (P00J).
If it is then here is a supplier of a used LCD screen only. (no digitizer I think)
Alternatively here is a new replacement part (complete) from this supplier (click on display check box )
If you decide that it is the same, then it is not a recommendation to use either supplier . It is only to show what may be available and the cost of the part.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
Is there a specific reason why you would not recommend this supplier and yes that is the same model that I need
Hi,
There's no reason either way, good or bad.
It's just that I haven't dealt with either of them myself so I don't know what they are like to deal with etc. and didn't want to give you a wrong impression about them, by implication. You'll have to use your own judgment regarding who you would prefer to deal with. Perhaps I should have said it another way.
Apologies if I confused you.
過去 24時間: 0
過去 7 日: 7
過去 30 日: 9
今までの合計 5,517
2 件のコメント
I am having the same problem, Have you had any luck?
patmajerus さんによる
https://www.asus-accessories.com/zenpad/...
Here is a link I found for the Verizon model screen replacement.
Tylor Slack さんによる
