メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
What is the problem occurring in my phone I dont know how to solve it?
It switch off during working.!! And when i am switch on it shows apple logo for 5 to 10 seconds and then showing blank screen and then switch offs again..!! I restart it and updated software and dfu mode.!! But it is showing again and again..after restarting it works properly for 1 or 2 days but after that tha problem occuring again and again..!! What should i do..!! Pls answer
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If it weren't the fact that it does appear to work for a day or so, once in a while, I would suspect the battery as being at the end of it's life. Still, to be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 70% of design capacity will require replacement.
If the battery is fine, then you likely have a logic board issue. Has anything happened to your phone recently such as a hard drop, a repair or contact with water?
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Bro how to check battery life of my phone?? Can u explain the process??
さんによる
Download one of the applications I recommended, install it and connect your phone so that it can give you the design capacity.
さんによる
コメントを追加
回答を追加する
Vinay さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 57
