Samsung tv screen broken
Samsung tv is displaying a small 2cm long horizontal line that is multi colored. No present when tv is off
the lines can be caused by faulty connections on edge of screen I would be thinking the screen has been damaged and causing lines.
Sometimes this can be fixed by adjusting the screen mounts and ensuring all connections are in correctly, a loose screen connection can also cause this.
Sometimes this cannot be fixed and screen replacement is required.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 508
