メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
earspeaker dosent work (i think I shorted it out)
i took my iphone apart to replace a faulty vibrator motor... after i replaced it i was reassembling it and when i wanted to connect the screen with the nr. 3 connector i accidentally touched the pins with a screwdriver, and i saw a small spark ... i noticed a very faint smell of (burning electronics)... i managed to re assemble the phone.. i turned it on, seemed to work fine.. i tested the touch sensor ,home button, proximity sensor, ambient light sensor, and they all worked but when i got to testing the earphone it didn't work...
i think i shorted something out... but i don`t know if it is the speaker itself or something on the motherboard...
if i order a replacement earspeaker will it resolve my problem???
any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Sparks are not a good thing during a repair. If not the earspeaker, then Flex Cable #3 would be the next part to try. If that is not it, then Logic Board.
The most fragile part in this complex of parts is the Flex Cable #3, then the #3 connector piece, then the Speaker itself. But with sparks flying who knows.
Good luck,
Brad
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
The ear speaker is just a simple magnet, there isnt anything to "short" out on that, I would check the #3 ribbon if you're having ear speaker issues. Does the proximity sensor work?
さんによる
what is the purpose of the very very fine copper wire wound round the speaker then? I would have thought that this could easily be damaged by power surge..
さんによる
The speaker is like a magnet. Sound is induced by electrical current to move the membrane, but there isnt anything to actually "short." Its like when you wrap a copper wire around a screwdriver and connect the leads to a battery. You basically create an electromagnet.
さんによる
so looks like you are in agreement with what Brad stated..
さんによる
If a current surge passed through a hair fine wire it wouldn't damage it? Prevent the electromagnet from receiving power?
さんによる
4件以上のコメントを表示
コメントを追加
The speaker isn't damaged. It is the #3 ribbon cable. You can get one off ebay for $7 or less and make sure you search for US only. This cable is a little tricky to install because the metal clip that hold it in is quite sturdy. Bending it a little bit is okay, but make sure you bend it back. That is really the only thing I can think of that got damaged. I highly doubt it is your logic board. But I guess there is a small chance it could be. Hope that helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ignat Robert さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,496
