Console powers up then turns off
Ps4 slim turns on, fan attempts to start but does not, unit powers down. No blue light of death. was wosking with no issues 8 hours ago.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First make sure that it's plugged in to a wall outlet that is working and the cable is fully plugged in to the rear of the console.
If there are bugs in your house they probably got into the power supply and killed it.
If none of those are the problem it's possible that the power supply is faulty. That all being said there's no way for me to know for sure without having it in my shop to test.
Hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 8,729
3 件のコメント
Buy a can of compressed air and blow into the PS4 airvents. Seems that the system is turning off because the GPU and CPU are not getting cool enough and the system is protecting them.
If the fan is not turning on after using the compressed air, it might be that the PS4 have a fan failure and needs to be changed.
Mauricio Gloria さんによる
Your problem has nothing to do with it not getting cool enough ^^^. First, make sure that your power cable is fully plugged in to a wall outlet with a known good power cable.
TronicsFix さんによる
My PS4 turns off right away when I get in the main lobby of any game, fan is working and everything I don’t know what it could be
aaronhr03 さんによる
