メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Replace the battery with new one and next day won't charge
Iphone wouldn't charge.
Got the kit from Ifixit, replaced the battery, which had approx 50 percent charge.
Everything worked fine, plugged it in, it started charging.
Next day, it is not charging at All!
I have tried plugging it into different places and nothing.
Googled it and found a number of complaints with this exact issue on ifixit questions.
What gives??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
There could be dust on the battery’s connector or it could be that the battery was badly connected. There is also the posibility that you were too harsh when connecting the battery, breaking or bending a pin from the connector itself or the battery’s cable. Check the connector again and clean it with compressed air or Isopropyl Alcohol and a Q-Tip. Hope I’d help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
disconnect the battery and while its unplugged connect a charger. if the phone shows an apple logo with battery disconnected then its most likely a bad battery. if nothing happens you have a tristar issue which requires microsoldering to fix.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i just reread ur post and im like 90% sure bad tristar ic. when the chip fails its common for the phone to not be able to charge a completely flat battery.
さんによる
コメントを追加
回答を追加する
Rene Davey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 34
