How to replace front panel? (nokia 6760 slide)
Does you have an tuturial, or some instrutions to replace the lcd front panel to the nokia 6760 slide?
xavier pinto, I have the service manual for your phone right here and please feel free to download it. The complete dis-assembly of your phone is documented on there and this should help you to fix it. Good Luck and let us know how it is going.
このアンサーは役に立ちましたか?
Hi all,
Just tried to use the link above posted by oldturkey & it aint working for me. Says something about the account viewing rights. Can anyone help me please?
このアンサーは役に立ちましたか?
simon give it a try now, my space is limited so unless I know people are needing the manual I usually remove it after a couple of weeks...:-)http://www.keepandshare.com/doc/2735076/...
I also wished to find out how to replace the LCD panel. I could not seem to contact oldturkey03.
However I found a copy of the service manual at: Nokia 6760 Service
I hope this may help anyone else looking.
このアンサーは役に立ちましたか?
Link on manualslib to the service manual.
Hi, I found some web pages that might help you with replacing the front panel of your Nokia 6760 slide phone. Here is a summary of what I found:
I hope this information helps you with your repair. Good luck! 😊
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 3,190
