メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
Why is my battery not charging?
I recently installed a new battery in my Early-2013 MBP that I bought from ifixit.com and followed the instructions on this site. After the battery replacement, everything seems to work fine. The battery was charging normally, and it showed about 10-12 cycles in Coconut Battery.
I went on a vacation for three weeks, during which the Mac was kept in sleep mode. After I retuned, I opened my MBP to find that the battery was no longer charging. I am getting a "Condition: Replace Now" notification in the menu. Also, see attached Coconut Battery screenshot.
What might have gone wrong? How can I fix it?
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It's always a bad idea to let these modern batteries drain completely and that's what happened with letting the Mac in sleep mode instead of turning it off. However, even if completely discharged, a new battery shouldn't stop working and behave as a years old one. Ask for replacement enclosing the screenshot you posted, not much else to be done.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks a lot for your reply. I will get in touch with ifixit customer service.
さんによる
コメントを追加
回答を追加する
Tushar Gupte さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 287
