Electric start Won’t start just clicking
I have a brand new mower. Charged it for 10 hours it won’t start just clicking!
Does the mower start when you pull the rope? If so, then your electric starter is bad. You need to take it back to the store for repair or replacement.
Even if the mower won't start when you pull the rope, since the mower is brand new, take it back to the store for repair or replacement.
このアンサーは役に立ちましたか?
I have the same issue, except I've had it for a couple of years. Mine recently started misbehaving and not shutting off when blade control handle was let go, and took me pushing the little metal switch thingy on the mower in. I recently fixed that, and electric start worked for a bit, and then suddenly it wouldn't start anymore. So I bought a new off brand mower only to have it suddenly start running slow, and it's self propel quit working. It of course has an engine that needs primed (terrible design if you ask me). Then I managed to fix the mower after discovering the ground wire was half broken, so I redid the ground wire (the one that's under the shroud/engine cover.) And replaced the cover and lo and behold it started but then later on electric start stopped working at some point. It still starts with the the pull cord, but also it will sometimes spit black exhaust out when starting. Not a lot, but once it gets up to speed meaning the engine, no color to exhaust which is good. But when you shut it off it smells strongly of fuel. I've done carb cleaner and fuel treatment and it runs better, but still does the black exhaust.
このアンサーは役に立ちましたか?
when I push my starter button it clicks and then I get nothing. Have to pull the cord to start. Battery is charged.
このアンサーは役に立ちましたか?
I turn key and it clicks repeatedly. I have just charged the battery.
このアンサーは役に立ちましたか?
I don't have a pull start
過去 24時間: 3
過去 7 日: 5
過去 30 日: 45
今までの合計 1,793
2 件のコメント
sandra castelluccio just for completion sake. What make and model is your mower?
oldturkey03 さんによる
Troy Bilt 280 TB
Joe さんによる
