メインコンテンツにスキップ
任天堂GameCubeコントローラーDOL−003。2001年11月に発売され、任天堂 GameCube、Nintendo Wii、Wii UとNintendo Switchと互換性があります。このデバイスの修理は簡単で、一般的なツールが必要です。
Why is my right trigger keep activating without me pressing it?
The R trigger is very sensitive to the point where it feels like if you even shake it, it will register. In games like smash 4, this has caused menu's to be rabid, and hard to select which mode I want. I air dodge and roll all the time unexpectedly. I am comfortable with a full tear down if any solutions require that.
So I've tried cleaning the sensor with rubbing alcohol, and cleaning the sliding rails, but it hasn't fixed it. I'm including links to show the problem and the controller.
https://1drv.ms/v/s!AjuAwwVhXweQkAmUD8Qd... - link to controller monitoring
https://imgur.com/a/0ZGXOI4 - link to inside the controller
https://www.youtube.com/watch?time_conti... - link on how it affects games
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There might be a foreign object present in that part of the controller. Taking a magnifier and a bright light can help you find that object. If there were no foreign object preset. Replacing the film is the last option.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I don't know what the film is, but I have made sure the controller is clean. I have some videos added to my answer to show what I'm talking about.
さんによる
forget about the film. The rubber might be the problem. the rubber is the only thing that makes contact with the sensor. clean the black dot. and clean the point where the black dot touches it.
さんによる
See, I've cleaned it with rubbing alcohol, but its the slider thats making it do it. In my monitoring link, I can see that the button isn't being activated randomly, but its the controller slider. Which I'm not able to see how to fix, since I don't really see the problem on the controller.
さんによる
did you find a solution?
さんによる
コメントを追加
回答を追加する
Ronak Patel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 26
今までの合計 2,901
