メインコンテンツにスキップ
The Razer Phone is the first generation phone by Razer released in November 2017.
31回答 すべてを表示
I dropped my Razer Phone and the lock button no longer works.
I dropped my Razer Phone and now the lock button doesn't turn the phone on or off. The only way to turn on the phone is by double tapping the screen. I have a feeling the connection between the button and the place its connected to disconnected in the drop but I'm unsure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello Jacob,
When you dropped your phone, did it physically dent it in and it no longer clicks, which is what activates the on/off action, or you just dropped it and although it is in good condition, it will just no longer work? Either way, you may have damaged the flex cable responsible for the power button and it most likely will need to be replaced. However, if the power button is dented inwards, you will need to get a dent remover for your phone (they sell them for iPhone's, but I do not know about the Razer phone) and straighten the dent, then put in a new power button. If taking out the dent and or a new power button flex cable does not work, then you may be out of luck and may want to try reaching out to Razer as you should still have a manufactures warranty.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jacob Sellars さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 1,414
