メインコンテンツにスキップ
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
63回答 すべてを表示
Why do my blinkers flash on an off so fast. but do not work .
left turn signal not working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
When one turn signal bulb blows, it has the following effect.
Dashboard signal indicator will blink at approximately double speed. This is an easy way for the car/truck to inform the driver that one of the bulbs has failed. this is actually a Feature. Anytime blinker indicator speed increases it means that the electrical system isn't drawing enough current.
just check the side of the auto that has the fast blinking. i'm pretty sure you''ll find a blown bulb on that side of the truck. Remember that there are often more than just the 2 bulbs (front and back). many autos have a side marker light on the fender that also blinks.
now if you experience Fast blinking on both sides and don't find any blown bulbs, then the problem your issue could be with the actual blink controller. i know my car has the blinking controller embedded in the CAUTION BLINKER SWITCH, and in my case i'd have to source an Emergency Blinker Switch to rectify the problem.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
fast flash on dash is a bulb out indicator
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tiarreahdar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 23
今までの合計 283
