iSight camera cable pinout
Hey everyone!
I broke my iSight cable on my 13-inch MBP Early 2011 and I bought a replacement cable to cut it and mend with existing cable. I noticed the colors of the 6 internal wires of this cable does not match to colors of original cable's wires. To do so, I need to match the 6 wires pin by pin. Does anyone know the wire colors and their associated pin # on the iSight camera cable? So i can match the wires using a multimeter.
Thanks in advance,
Jorge Mendes
PS: Buying a full display unit or (me or another tech) taking the risk to crash the display glass trying to open it are completely out of question.
Update (03/18/2020)
I took the courage to open the front glass without crack it and connect the cable from outside, between motherboard and the camera. But it did not worked. I believe the circuit on MB had damaged then the cable breaks. So, I let it go.
この質問は役に立ちましたか?
1件のコメント
I have the same issue. Did you manage to fix it? I would like to buy a new cable and try to solder it
Francesco Andrisano さんによる
