メインコンテンツにスキップ
Released in 2009, identified by number A505-S6967. Black mid-size laptop with 40.6 cm screen and silver Toshiba label.
2回答 すべてを表示
Does not turn on but blinks
Just replaced screen which was pretty simple via YouTube clip. Double checked connections. Worked fine then after about 20 min it powered off. Now power light only blinks. Haven't used a battery for over a year because it's no good only used power cord. I tested the cord with a flusk 36 meter works fine at 19.4 volts. Tested inside connector from board to power...works fine 19.4...still blinking. Any help would be greatly appreciated...thks.
PS....laptop had not been used in over 9 months.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
An easy and inexpensive thing to try is to replace the CMOS battery. It's likely time to do that anyway. A dead CMOS battery can make a computer appear to be dead - this happened to me. When I replaced the CMOS battery, the computer came back to life.
If that doesn't fix it, you've lost only about $5. And you probably should have replaced it anyway, even though replacing it didn't fix this particular issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rayferr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 215
