メインコンテンツにスキップ
Repair guides and support for the Toshiba Satellite P850/P855 laptop series.
5回答 すべてを表示
Screen went black after battery got low
Low battery came across screen but before I plugged in computer screen went black. This has happened at least 2 times recently. And it took trying to turn on 3 plus days before screen came on. Tried the function F8 shift and power over 6 times did not work. What to do ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like your computer automatically went into hibernate mode when the battery got real low, and you couldn't get it out of hibernate. If you disable auto-hibernation, you will eliminate this from happening in the future. Keep in mind that by disabling auto-hibernation, when the battery runs out the computer will just "crash" - it will simply turn off if there is no power. The good thing is, it won't be stuck in hibernate mode, because it never went into hibernate. But you will lose anything you were working on and didn't save before the computer ran out of power. To disable auto-hibernation, go into Control Panel and change your power options.
There is also a power option which will turn the display off when the battery gets down to a certain amount of charge. You can change that option to keep the display on as long as there is any power at all in the battery. Or you could change it to where it dims the screen rather than turning it off when the battery is run down almost all the way.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks, very helpful
さんによる
コメントを追加
回答を追加する
Janice Watts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 1,307
