メインコンテンツにスキップ
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Agitates while filling and rinses while spinning
My 6 yr old Kenmore washer has started agitating while filling and pouring water while spinning. I've had to leave the lid open initially and then turn the water off during the spin cycle. Thank you for your help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
The problem could be a faulty timer or pressure switch. I recommend unplugging the washer and opening the console. I have provided you with the instructions for accessing the console below. Then locate the pressure switch. It is the part that has the small hose connected to it. Once you find the pressure switch, unplug the wires to in. then plug the washer back in and start a wash cycle. If the washer does not do anything, the pressure switch needs to be replaced. If the motor still runs or makes noise the timer needs to be replaced.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Please clarify "unplug the wires to in" I don't understand. thanks
さんによる
@Ed Castle
I think it is a typo and it should say "...find the pressure switch, unplug the wires to it."
What is the model number of your washer?
さんによる
コメントを追加
回答を追加する
Marc さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,822
