メインコンテンツにスキップ
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
265回答 すべてを表示
Sound distortion from the speakers on MacBook Pro (Retina Late 2012)
So I have this MacBook Pro for about 2 years and it seems that both of the internal speakers are providing distortion to the point that I can't even use them anymore I have to use the equalizer to turn the bass all down so that I can hear it a little.
I read a comment somewhere that they can be fixed without needing to replace them. I wanna know if there is the guide or a way which I can follow to try to get them fixed without needing for expensive replacement as it seems that both of the speakers required replaced or fix.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Hi,
Any did you find any work around?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
See if the problem persists if you log on as a guest user when booting up and let us know.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Problem still persist. The sound even distort when its botting up. That means its not the software problem. Moreover I have tried reseting the SMC and P. Ram but this problem remains the same. I'm sure that its the speakers causing this.
さんによる
コメントを追加
回答を追加する
azn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 2,160
