メインコンテンツにスキップ
Joy-Conは、ニンテンドーSwitchゲームコンソール用のコントローラーです。
167回答 すべてを表示
After opening the Joycon, it works only attached to the switch.
The thing is: I messed it up.
I tried to put a transparent shell on my joycon and the right one now can only work attached to the switch. I've already cheked the battery and it's working fine.
I think it's something related to the motherboard, but I can't tell for sure. Someone here have a better understanding about the joy con circuit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Cheers mate.
Not sure if it's the same issue I had, but in my case the SL button wasn't connected to the joy cons mainboard. That's why I couldn't use it in horizontal mode, but attached to the Switch.
Hope that helps.
Regards
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello!
Actually I've already sent it to the repair support. According to them, anything could have caused this, but unfortunatelly it really was a motherboard problem. I don't know how I managed to break it, but I just had to use another Mobo and now everything is working fine.
さんによる
コメントを追加
回答を追加する
kleberlauton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 1,202
