メインコンテンツにスキップ
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
20回答 すべてを表示
Can not switch on bike after a few weeks pause
Hi, I have not used my Qicycle for a few weeks. Now it can not be switched on anymore. The battery is fully charged (all LEDs are lit) but the display is dead. Does anyone have an idea where to start debugging? does anyone know the problem? I'm grateful for any hint!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
8件の回答
最も参考になった回答
Have you tried removing the battery from it's seat and then putting it back?
Then turn on the trip computer by holding the on/off button for about 3 to 5 seconds.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
This works, but now i have to do it every time i want to turn on the bike. What would be the solution for this?
さんによる
コメントを追加
I fixed my problem in the end by opening the display/controller thing om the steering bar. Inside a contact was a bit corroded, so by cleaning that it was fixed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Your inner power button must be displaced
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Do you have experience with a malfunctioning power button? It seems like that is the problem I have. I managaged to turn the display on once, after trying a lot, but now in the menu the button again doesn't respond. The up and down buttons do respond as they should. Should I open the controller to see if I can replace the button?
さんによる
Where is that inner power button located?
さんによる
コメントを追加
I have exactly the SAME question! 3 weeks off, on the balcony - very hot (I live in Italy)… now display is DEAD
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same thing happened eith my display. I left the bike outside for lunch. When I got back, the display only lights up but nothing else.
さんによる
コメントを追加
My Qicycle all instruments are on. Batt is good. Display is good. All lamps work good. But when I hit the pedal, the motor won’t work. Now, it almost 1 year in my room. I went to several e-bike service center. None of them can fix the problem. No parts available in my country. And it seems they are all did not know what happen with my bike. One said about the controller. Another said about the motor. Very confused and make me frustrated. Now, the bike still in other technician. He try to check one by one. Flow of cable, sensor, controller, motor, battery. I just hope he will find the solution and my Qicycle in on the way again to my daily work vehicle.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, even here in the Phil. parts are scarce to find. Only hope is aliexpress. But many sellers have ran out of stock or are not willing to ship. I traced the company, even though its mostly made in China or xiaomi is a Chinese brand; this "qicycle brand" is actually Korean.
さんによる
コメントを追加
how do you change the language on the display to english?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
https://3dparts459136784.wordpress.com/h...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello, did you manage to get this problem fixed? I'm having the same issue :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tkehrberger さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 14
今までの合計 1,860
