メインコンテンツにスキップ
The Toyota Sequoia is a full-size SUV manufactured by Toyota and derived from its Tundra pickup truck. Introduced in 2000, the Sequoia is the first vehicle from a Japanese marque in the popular mainstream full-sized SUV class in North America.
11回答 すべてを表示
03 sequoia abs Auto bleed option
Newby to Toyota's. Having a problem using the auto bleed option with my scan tool to get the air out of my abs pump. The scan tool asks me to "unplug any relay or plugs according to the repair manuel". I am unable to find any such reference as to which relay or plugs to remove. Which repair manuel?......Help! Please!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@gcr that is a very vague description. I'd check the brake part of the manual and I would think by plugs it could be the bleeder plugs. Take a look at this for an'05 but should be identical Brakes.pdf Instructions from here should also work for your vehicle
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gerry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 449
