メインコンテンツにスキップ
2015年9月発売。JBLXtremeはポータブルなBluetoothスピーカーです。
103回答 すべてを表示
Is it possible to run JBL XTREME without battery?
Hello,
My JBL Xtreme is not charging, not working. Just blinks one led white then blinking red and repeats.
I have removed the battery and connected charger, it did not worked. And same blinking.
I have disconnected the charger and connected DC 8V power source to power socket on board. No lights came out but it sinks current 0.25 A. I have tried to power on but no luck.
So if my JBL XTREME doesnt have a motherboard issue, is it possible to run it remove the battery and connecting device to a constant DC power source.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント:
i have the same issues
さんによる
I have bought 2 charger cords in 1 year. These speakers are garbage and I will not be buying another. Almost $100 for a new cord…lol
さんによる
コメントを追加
3件の回答
Yes it is, i just removed my own battery, the unit is working fine
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
How to power the jbl Bluetooth speaker when u remove bettery. How we can give it direct power without bettery
さんによる
i'm trying to do the samething with a boombox. bypass the baterry and give power from the ac board to the motherboard. but i didnt know how for now
さんによる
How long time your JbL working without the battery? Its safe ??
さんによる
@ghostparris472 it doesn’t work
さんによる
コメントを追加
My jbl extreme its still work without battery with power supply from charger (after im removed that battery).. but im worried if use it for long time
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My extreme 2 speaker has one bar of battery life left. It powers on but won't charge. I have taken the battery out and connected the wall charger and it does not power on. I'm thinking it's a power cord issue. Will be buying a new power cord
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It’s not a cord issue,I’m suffering same
さんによる
I have the same issue now, did you find any fix for it?
さんによる
totally same problem here
discovered power supply to the battery is out haven't fixed mine yet since am in Nigeria and things are hard to get but iv'e been experiencing a delay in charging response might be charging unit
さんによる
コメントを追加
回答を追加する
the_mesa さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 37
過去 30 日: 144
今までの合計 10,280
