メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
425回答 すべてを表示
Phone only works or charges with rear cover removed. Possible causes?
I replaced the LCD, battery and rear cover on this phone. I tested it before attaching the new rear cover, the screen worked, and the phone went through a charge and discharge cycle as normal. Then I replaced the rear cover and left it to sit under some slight pressure while the adhesive set overnight.
Next day the screen won't come on, and there's no indicator lights when I plug it into a charger. My USB ammeter shows it drawing only 0.17A -same as I've seen when this phone crashes or shuts down after a boot loop.
Has anyone observed this behavior before? What could cause the phone to work only when no rear cover is attached?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
That is really odd.. it shouldn't matter if the back cover is removed or not. Is the battery or charge port damaged in any way?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not visibly at least. And when I was testing before replacing the rear cover it showed the expected charging amperage when plugged in.
さんによる
コメントを追加
If you remove the back glass again will it power on? It is plausible that your adhesive may have got onto the motherboard and is shorting something? although not many adhesives are conductive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephen Barnwell さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 14
今までの合計 111
