Darts stuck up in chamber
On firing, the plunger moves ahead, but the dart does not come out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Is it possible to put you finger over the chamber hole behind the revolver? Mine is modded so that the revolver swings out further, so I don't know if you could reach it normally. If you can, check to make sure it blows air out when you fire, or you may have a plunger issue. If it does blow out air out, make sure you are using Nerf brand darts, and that the barrels in the revolver are free of any debris or grime that could be blocking the darts.
このアンサーは役に立ちましたか?
Check the teardown guide Nerf N-Strike Maverick Teardown as well and make sure the spring and the plunger line up the way they are supposed to ...Happy hunting..
it is possible that the darts that you are using are to large for the chamber and or barrel of the gun.
このアンサーは役に立ちましたか?
i got a battery stuck how do i get it out
過去 24時間: 1
過去 7 日: 6
過去 30 日: 8
今までの合計 5,884
