メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why is my iPhone 7 in reboot/recovery mode loop?
5 weeks ago, I dropped my iPhone maybe 2 feet onto the ground. After rebooting twice, it worked just fine. About 3 weeks later, it began rebooting again and has not stopped since.
I know the problem isn't the battery because I'm about to get the phone into Recovery Mode (where the "Connect to iTunes" prompt appears) and have it stay there for extended periods of time. I'm also able to get the phone into DFU mode and had it stay in that mode for over an hour before I forced started it, so the battery shouldn't be an issue.
Currently, it is in Recovery Mode loop, where every time it turns on, it asks to be connected to iTunes. However, using ReiBoot, I can get it out of Recovery and back into the reboot loop, which isn't much better. I've tried both updating and restoring in both Recovery mode and DFU on both PC and Mac using a genuine Apple lightning cable, but every time, the iPhone reboots when iTunes gets to the "Preparing iPhone..." portion, looping back to Recovery Mode, and in the process giving me the 4013 error on iTunes.
Any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You have done the basic trouble right, so now we need to inspect the board. If you don't have the proper equipment/knowledge on boards I would probably look for a shop near by that specializes in it. Most likely, the dropped may have affected the board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
zekurokuxakurokuaddict さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 185
