メインコンテンツにスキップ
HP Photosmart Premium Wireless All-in-one Color Inkjet Printer/Fax/Copier/Scanner introduced 2009.
Why is my printer not printing from the wireless computer commands
why is my C309a HP Photosmart Premium printer is not printing from the wireless computer command?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Could be several things. First, I would verify that the computer and printer are connected to the same wireless network, then, print a configuration page directly from the printer panel. Verify the IP address is the same as the one in your printer icon in the computer printing settings (on computer). If different, add the new ip address to the printer icon, print test page. You have to so this again, if you don't make you ip on the printer static.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Using the onboard display, go to Wireless. Somewhere you should be able to print a Diagnostics page. This should tell you if your Radio (more commonly known as Wi-Fi) is turned on and is working. As of April 2020, it said that my Radio was not working and I found out many of the cards were defective.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
joch1203 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 384
