Status bar has turned grey
The status bar on my new vivo xl3 has suddenly turned grey and the battery monitor does not show green when charging. Any ideas on how to fix the problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well, i would start by checking if power save mode is on. turning it off could fix this. Registering multiple colours is a power consumption, and may be turned to greyscale if the device is trying to save power.
if not, check battery settings, as well as display settings carefully to see if vivo settings will let you change them.
When was the last software update you did? did it start recently after that?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 373
