メインコンテンツにスキップ
ヒューレットパッカード(HP)は1993年よりパーソナルラップトップコンピューターの製造を開始しました。
2970回答 すべてを表示
Laptop does not start up without it being plugged in?
I got a HP 15 bs007ne last month and I have noticed that it never boots up if its not plugged in and charging. As soon as i plug it in to charge, it'll start up. This always happens no matter on what percentage it is. Once its on, I can take if off charging and it will work normally. I am so annoyed. I have to carry a charger to college and its definitely a hassle. Please help x
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi @khanyehasprobs ,
If it's new take it back to where it was purchased or follow the instructions in the manufacturer's warranty statement (usually found in the User guide) as to what to do to make a claim for a manufacturer's warranty repair or replacement.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Is a faulty battery included in the warrany? its been a month since I bought it
さんによる
Hi,
It should be.
Check the warranty statement as to what is covered by the warranty and for how long.
They say in this link "1 year limited parts, labour, and carry-in service;".
Usually "limited' means that if you drop it or get it wet it is not covered.
It may be that the warranty is different for your location (depends on the rules of the country as to what the maker can get away with), that is why you should check the warranty statement that came with your laptop, as it will apply to your situation (unless you bought it in another country and then moved)
さんによる
コメントを追加
If you just bought it take it back. Odds are high that you've got a faulty power lead or bad battery. Return it and get a new one. If the store wont exchange it you're going to have to go through HP's rma process. Good luck hope I helped.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you! its been a month since i bought it. does the warranty support faulty batteries?
さんによる
コメントを追加
回答を追加する
That1pakigirl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
