My asus stuck on logo!
My asus 2-in-1 wont boot past the asus logo, and keeps restarting
I have tried to boot from usb (windows 10 media creation tool) from bios but it doesn’t work.
Please help!
Hi,
Insert USB recovery drive into laptop.
Start laptop and get into BIOS (press F2 after power on and before Windows "boots") and enable Legacy USB or CSM (not sure re your laptop).
Change boot order to USB 1st boot option, save changes, exit BIOS and restart the laptop.
When in Windows Recovery Environment, select Troubleshooting > Advanced > StartUp repair and follow the prompts.
Do not select Reset this PC as you can erase all your data and reinstall Windows if you are not careful.
このアンサーは役に立ちましたか?
I have tried that, there’s no csm option in bios but i changed the boot order to usb and its still doing the same, it doesn’t seem to work
[fixed]
The problem is fixed
I was trying to boot my 32 bit pc with 64 bit windows
Just made another bootable usb with 32 bit windows this time and its working fine.
Thank you for your consideration
このアンサーは役に立ちましたか?
how did you get it to read the USB?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 2,519
