メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
141回答 すべてを表示
What would cause my car to accelerate after ive braked?
I drove to work today, when I left home I felt that the car was accelerating by itself. I let it hit 40mph before I pressed the brakes. When I stopped at a stop light the engine sounded like it was revving a little. Then I released the brakes and gave it a little gas and it sped right up and I had to keep tapping the brakes to go the posted 25mph.
Now, it's been having some problems leaking the coolant and we just continually pour in coolant and water...it's getting expensive. What can I do to fix the acceleration problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
6 件のコメント
Skippy722 The exhaust is WHITE! lol yes what exactly would that mean?...and your advice before was a vacuum leak. Fixed! The car doesn't speed up anymore. Thanks for that one!
さんによる
White exhaust may clear up since you fixed the vacuum but give it 50 miles. After that if it continues look here: http://www.ehow.com/facts_4965624_white-...
さんによる
+one to mayer (can't actually rep you). It definitely sounds like you have a blown head gasket if you keep having to pour coolant into it
さんによる
I've got a better one for you today, my car accelerated by itself but I couldn't accelerate by hitting the gas!!!
さんによる
I was reducing speed and there was a burst of speed. It felt like I was in the wrong grear. I have a 2013 Chevrolet Malibu Lt
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
選択されたソリューション
Your car either has an electronic or mechanical throttle. Electronic meaning theres a sensor that tells the throttle where is should be, mechanical meaning there's actually a cable that goes from the pedal to the throttle. I would need to know which to accurately help. If it's electronic, make sure the pedal returns all the way to where it should be (pull it up slightly with your foot or hand while the car is off, if it comes up get it checked out, if not you have a glitch in the computer somewhere or a bad sensor). It it's a mechanical link, make sure the throttle (it will be near your intake manifold) moves smoothly and returns to where it's supposed to be... You could also have a vacuum leak somewhere, so check all the hoses coming off the intake manifold and such to make sure they're connected and not split. Sometimes you can't see a small hole in one of the hoses, just an F.Y.I.
As for the leaking coolant, check your radiator and hoses to make sure they're not leaking. If they're fine, then the leak is coming from either the heater core or the block/heads, which is pretty costly. Is your exhaust invisible after the car is warmed up?
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
Thanks skippy722. Exhaust is visible when warmed up, began to sputter. I was told it could be the spark plugs....(?)
I think I'll start with looking at the vacuum leak, I did remove the intake. :) Had to get to the thermostat housing. Someone had replaced the thermostat for me and I found that the housing wasn't bolted back on right and there was a gap between the two pieces that meet. Tomorrow we plan on fixing that and replacing the lower hose. Should help with that leak. I'll let you know.
Thanks for you're help! Su
さんによる
Remember to use new gaskets when you put everything back together... I'm assuming your exhaust is white in color? You might have to remove the heads and have a look. Thanks for keeping me updated, and it's a pleasure to help :)
さんによる
+ very nice and good answer.
さんによる
you good at what u do. I had this in my dads car. he doesn't care to keep up and I think he messed it up. He rather uber or have things delivered. Got concerns over just having the CV axle replaced. Im a girl and that didn't sound like that would fix the problem. figured it may have messed with it electronicly in some way. before this all started I had a new compreser placed in and it made sounds a few weeks later. I t made sounds like if I had a cup making noise in the car. Got it back from shop and it just stopped working. Then my dad drove it and it accelerated again on him.
さんによる
My 2003 f150 just did that to me. The gas pedal went down by itself and spec up. I was trying to brake and it wouldn't stop. Finally I rammed it up in nutrtal. Sacred to drone it again. Any advice? ..help
さんによる
コメントを追加
回答を追加する
Sue さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 82
今までの合計 98,709
