メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
260回答 すべてを表示
need help with speaker replacement
Opening up my late MBP I messed up the membrane of my left speaker, an authorized Apple repair center quoted me 650 euros to replace the entire top case (the speakers are glued to the body of the MBP).
I managed to find a set of speakers for 70 euros harvested from a dead machine, so it is possible to remove them.
I was wondering if anyone knows what is the best way to soften the adhesive? Do I need to use heat? Is it the same glue use for the battery? Do I need to get the battery solvent?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The iFixit Adhesive Remover is great for that job. I use that adhesive remover for all my adhesive destroying needs. You can use Tesa tape as new adhesive too, if you wish.
Tesa 61395 Tape
iFixit Adhesive Removerの画像
製品
$19.99
Tesa 61395 Tapeの画像
製品
Tesa 61395 Tape
$5.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. Did you fixed the your speakers?
I need to fix a left speaker and I already bought it from iFixit.
My problem is how to open the back plate of the MacBook, I think the screws are Torx 3. The screw is very tight in place and it is made with a hard metal, the Torx 3 driver bought I has a soft metal. It end up making my torx lose the teeth. I was very gentle but it did not help.
I would like some advice on the matter.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The screws on the backplate are Pentalobe ones, not Torx. Use a Pentalobe screwdriver.
さんによる
Here is an update the my problem.
My MacBook Pro has having issues with the keyboard and it finally gave up. 4 Keys loose the caps and and 2 were at working at all.
I made a backup and took it to the Apple Authorized Repair Shop and the exchange the top shell where the keyboard is. Since the speaker are attached to it, it also fixed the problem with the speakers.
Because the notebooks have the Repair Program for the keyboards, I did not had to pay anything.
Now my MacBook Pro looks, works, and feel like a new machine.
A big thanks to all MacBook Pro users that complained to Apple about the keyboard, it is the best and the right way to do it.
さんによる
コメントを追加
回答を追加する
Emilio Lari さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 226
