メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Model 917 Differential Problem
Tractor, YTS4000, 24hp 6 speed manual-- has difficulty turning. To me it seems the differential is locked as the front wheels continue to want to plow forward while turning. (This is not a "steering" problem as the front wheels turn fine) What I see: This winter when using the snow blower as I attempted to turn right, the right rear wheel was spinning!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
You are 100% correct. It thinks it is a drag-racer with 'posi-track' !
さんによる
コメントを追加
2件の回答
ベストアンサー
@tlien this mower uses a transaxle. See if you can find a tag or manufacturers number on it. If there is none check the attached image for an ID and let us know if there is a match.
This is not an answer but the only way to post an image. I shall delete it once I have clarification from the OP No reason to downvote it yet ;-)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Need to replace the two Drive belts on a 42-in craftsman motor
さんによる
コメントを追加
最も参考になった回答
If you're a 'shade-tree-mechanic', you can save a few bucks by removing the unit, and take it to the shop for repair. Or, fix it yourself. These machines were not known for their longevity, plus differentials are expen$ive, so I would make it a D.I.Y. project.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Terrence Lien さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 433
