Building Own iPhone From Scratch
I wanna build my own iPhone from scratch and I wanna know that, I have a Housing without Flex. If I buy the rear cam, do i need to buy the bracket, connector bracket? Your help is appreciated.
Travel to China, spend at least a few months in Shenzhen, that's all you'll need to do!
Follow Scottys' travels here where he did it How I Made My Own iPhone - in China and do review what Scotty spent building his How Much Does it Cost to Make Your Own iPhone?
Getting the parts here in the states will cost you more than three times what the phone costs as there are just not enough junkers yet and even then you'll end up having to buy some parts a few times as you will likely get some bad parts as well.
このアンサーは役に立ちましたか?
Yeah but I kinda order from AliExpress, so the price will be okay. So should I buy those 3 parts or should I just buy the rear cam module and it includes both the bracket and connector bracket?
and... and... It's a lot more than that!
Luke 14:28 For which of you, intending to build a tower, sitteth not down first, and counteth the cost, whether he have sufficient to finish it?
Which baracket are you referring to?
The one that goes over the top of the camera or over the top of the connectors?
Either way they are not included.
The logic board is the most expensive part and hardest to source, especially seeing as it's going to have to include its matching home button.
このアンサーは役に立ちましたか?
Okay, thanks for telling. Appreciated that !!
I've already done this. Its great learning experience!
Go ahead and assemble your own iPhone!
このアンサーは役に立ちましたか?
I bought all my parts from eBay. It does cost more than a new. But I am committed now… any help would be appreciated. Using my droken phone to a new chassis . Some screw positions do not line up. Mainly offset screws.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 19
今までの合計 1,285
