engine knocks when hot when going slowly
engine knocks bad when hot only when trying to go slow like a drive through. put in neutral and give a small rev and it stops.
First things first, get it scanned and see what codes come up.
Knocking implies bearings, usually big ends and it doesn't usually go away with a rev.
But what you call knocking I may call pinging. So are you saying it sounds like an old diesel with that death rattle they have in the top end. Or are you saying it has a dull thudding noise coming from the bottom end?
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 97
