メインコンテンツにスキップ
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
22回答 すべてを表示
Why does my clothes dryer cause my power to go out at end of cycle?
I just purchased a new home (built in 1980) as well as a used washer dryer. I noticed the last two times I have done laundry that the washer dryer both run just fine, except when the cycle of the dryer ends. Right at the end where it would chime, the power in my whole home goes out for a second and then immediately comes back on. No circuit breakers are tripped. What could be the issue?
I know the outlet for the dryer is a 3 prong chord. Not sure if this is relevant.
Thank yoU!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@elizabethmarie "the power in my whole home goes out for a second and then immediately comes back on." without tripping a breaker is highly unusual. You can get a brownout situation if the dryer would pull to many amps from your power line, but that seems to be to far fetched. Double check the outlet and/or plug the dryer into a different outlet and see if that changes things. Let us know what make and model this is so we can try to get a wiring diagram etc.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Elizabeth M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 1,331
