メインコンテンツにスキップ
Why is my Zune not working
Microsoft Zune says contact support. I charged it up but it does not do anything. Right now on the screen it says contact support then they have the number five on it. Also a picture with an x on it. What can I do to get it to play music, games and other things that it used to do? Does it need to be updated? I had it for quite a while. A guy went to put music on it for me which I already had music and he was going to put more music on it. However when I went to play his music that he put on it. It just stopped working altogether. Can you help me. I know that is out of date but I like to still listen to the music that I have on it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
7件の回答
最も参考になった回答
If resetting it doesn't work, you should reinstall the software:
http://support.microsoft.com/kb/926993
Software available at: http://www.zune.net/en-us/products/softw...
You may lose music or other data purchased/added since your last sync.
このアンサーは役に立ちましたか?
スコア 7
3 件のコメント:
Is the software on the website or the cd that
Comes with it?
さんによる
I added the link to the software above.
さんによる
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market.
さんによる
コメントを追加
この回答は他の質問に帰属しています。
I fix these for a living, the number Five Error is usually the hard drive, sometimes the hard drive cable.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I've got two 120 gb Zunes, and one 30 gb. Both the 120's display this error screen; I believe the error message on the 30 was similar, but I cannot get it to appear again. Can you send me contact info if you can possibly repair these units?
さんによる
コメントを追加
この回答は他の質問に帰属しています。
i have a contact support 5 and there is a chip getting really hot on the motherboard.(looking from the back its on the lower right side, behind the back button on the back side of the board) still say 5 is the hdd or hdd cable?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
この回答は他の質問に帰属しています。
I have visited you blog and feel good to read comments about to fixing the zune error 5 and other but now i am focused about to fixing zune error 5 someone recommend me to visit this error site and feel the difference of services and i follow that person and really i have get a lot of benefits from this its solve almost every problem related to this error, I want to recommend you to visit this http://ezinearticles.com/?Fix-Zune-Error... and you also feel the difference between this and others sites.
Thanks
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
After replacing my zune LCD screen I got this message. I took the zune apart again and found that I did not properly replace the mother board ribbon. After properly replacing the ribbon, the zune worked fine. Hope this works.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market & A SHAME that MS ever ever stopped producing. But then again MS has never done too much right other than make the best music player on the market.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi Robert. I recently sent a few email messages to Rapid Repair (8/2023) but have not heard back. They don't have a phone number listed on their website. Do you happen to know who else can fix the number 5 error?
さんによる
They no longer deal with the ZUNE products & Can get no parts. You can buy a "parts only" ZUNE on EBAY, But You'll probably get the same bad hard drive ERROR 5. There are a few sellers on EBAY that sell rebuilt ZUNE's & they are fixed with a new SSD drive (much better )
さんによる
コメントを追加
この回答は他の質問に帰属しています。
I tried nearly everything to no avail.. just for the heck of it, I band my zune on my desk a few times and *poof* it started up just fine... yup, I pulled a Fonzie.
Can't make the problem worse!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gary Johnson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 477
