Coax cable broke off on back of tv
I have basic cable my coax cable port on the back of the tv broke off is there something i can use to convert the hdmi or another part of the tv so i can use the coax cable? Or is it repairable?
Hi, @geko1986 ,
You may be out of luck.
HDMI cannot tune into any TV channels. (FTA or cable TV). It is not a tuner.
The co-ax port is part of the digital tuner module on the mainboard. This is a sealed unit and difficult to repair.
If you wish to continue to use the TV, either replace the mainboard or get a compatible box which connects to your cable service and connect via HDMI from it. (if you mean when you say that you have "basic cable' that there is a co-ax cable FTA antenna lead into the TV then connect it to a HD set top box and tune into the channels using it and connect it to the TV via HDMI)
このアンサーは役に立ちましたか?
I had the same problem. Repairing the coax plug is difficult for an HD tv, most of the videos on YouTube are for older tvs - see link here https://www.youtube.com/watch?v=S9v-dUyz... . Buying an external tv tuner, sometimes referred to as a converter box, is probably the best answer (see jayeff’s answer). I bought this product https://www.amazon.com/gp/product/B07VNV... and it seems to work just fine for getting over-the-air tv broadcasts (not cable tv).
このアンサーは役に立ちましたか?
Were would I get the coaxial input for my tv
過去 24時間: 0
過去 7 日: 10
過去 30 日: 29
今までの合計 6,602
