メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1625。A8プロセッサと2GBのRAMを搭載したAppleのセットトップボックスの2015年改訂モデルです。
Apple TV 4 (A1625) Boot Looping
My Apple TV 4 is not able to fully boot up to the home screen.
It displays the Apple logo that you'd normally see during the boot process. After the light on the front of the device blinks 9 times, it seems to immediately reboot itself.
On just one occasion since this began, iTunes was able to see the Apple TV temporarily when I had connected it with a USB-C cable (with the intent to be to do a software restore on it, if possible).
I have tried two power cables (borrowed from another working Apple TV), two HDMI cables (not perceived to be an issue since we can see the boot logo on screen), different power outlets, and even different televisions.
There are articles on holding the TV and Menu buttons on the remote for 10 seconds to force it to restart. The Apple TV does seem to react to the remove (the light on the front will flash in response to it), but this did not permit a full boot.
Thoughts on what hardware components inside of this would be worth swapping out to get this working again?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
Before this issue began, the system was running tvOS 11.2.5, and was not enrolled to receive beta updates.
さんによる
Thx for the posted info. Worked like a charm after my old Apple TV 4 crashed after a power outage. Spent $10 to get a usb-c off amazon prime and it was worth it. You saved me a few $$. :-)
さんによる
コメントを追加
4件の回答
ベストアンサー
The trick is to get the Apple TV to boot in recovery mode. This can be a bit troublesome when it’s stuck in a boot loop though.
The following steps should get it there, and get it to show up in iTunes for a restore (which will fix it in most cases):
  • plug in usb-c
  • plug in power
  • hold menu + home until it starts blinking fast, then release
  • immediately after that when the light turns off, hold menu + play for a few seconds
it may require some fiddling, i’ve Had to spend up to half an hour for really stubborn atvs, but so far succeeded every time
このアンサーは役に立ちましたか?
スコア 24
18 件のコメント:
Thank you for the suggestion, Joost.
After holding the sequence as suggested, the ATV status light goes to a fast blink. However, iTunes doesn't recognize that a device is connected.
Are there other steps that should be performed?
さんによる
I disconnected the USB cable from the computer, and then shut it down and booted back up. This was all the while that the ATV was still doing the fast blinking for recovery mode. I reinserted the USB cable, and iTunes immediately launched and let me do a restore! Everything is working again. Thank you so much!
さんによる
Deu certo comigo tbm! Obrigado
さんによる
Finally! A suggestion that worked. Thanks so much.
さんによる
I tried home + menu buttons around a thousand times in a thousand different sequences with no success.
Then I tried home + play/pause and it worked.
With Apple TV plunged into MacBook and iTunes open press and hold home + play/pause buttons until the light starts blinking rapidly. Release buttons and it should reboot to recovery mode.
さんによる
13件以上のコメントを表示
コメントを追加
Thanks for your guide.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey folks! Just adding my latest experience. So my AppleTV HD crashed somehow and I would get the 6 blinks/pause/6 blinks, rinse, repeat. After much research and failed attempts, it dawned on me that maybe the updated remote I purchased to replace the glass/aluminum original version was a problem. (dropped, broken glass, still functional.) I still kept the old remote as a back up and charged it, as I was having not luck with the latest remote version that I had upgraded to.
I held down home + play/pause and the slow 6 blinks quickly changed to the rapid blinking light mode. I then connected it to iTunes, and the AppleTV appeared in the side bar, and I was able to do a restore on the AppleTV HD. So thank to everyone on this thread for their help with this issue. Much appreciated!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
AppleTV 4 (A1625)
iOS26.1 update knocked out my device. Stuck in flashing startup light. Performed above procedure for DFU mode. Be sure to update iTunes through Microsoft Store in Win11. Old app showed device but wouldn’t restore and no error message. Worked 02/26
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Any news how to get those without USB port fixed?
さんによる
コメントを追加
回答を追加する
dpw95 さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 78
過去 30 日: 255
今までの合計 26,258
