メインコンテンツにスキップ
Huawei Pモデルの修理と解体ガイドです。
797回答 すべてを表示
How do I replace a broken screen on the Huawei P Smart?
Hi, I have ordered a replacement digitizer for the P Smart but I can't find any tutorials on how to fit the replacement screen.
As far as I can see there are no screws visible to open it up.
Can anyone help or does anyone have any experience doing a screen replacement for a Huawei P Smart?
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
5件の回答
最も参考になった回答
The Part
https://www.tvc-mall.com/details/oem-lcd...
The procedure
https://www.youtube.com/watch?v=tN9e7xOJ...
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
just watched the end of the video. DO NOT USE A BONDING AGENT LIKE THAT. use 1mm double sided adhesive and DAB bonding agents on corners and sides. The amount they used can easily cause damage to components
さんによる
The part I have purchased is this.... https://www.parts4repair.com/touch-scree...
I bought this as the phone functions fine but the screen is cracked and I was l led to believe that only this part would need replacing.
Is this possible? thanks
さんによる
i havent done the repair on this device myself specifically, however, it may be possible.
i would need to physically hold the phone to see if the two parts are serperable. (you feel a little give, before it connects to the LCD)
if they are sepreable, then the repair is very similar, but you lift the Digi from the LCD instead of the whole assembly from the bracket.
I can not find any video guides for this unfortunately, so you will have to be at least some one intuitive to do this part.
さんによる
Thanks for your help Scott
さんによる
コメントを追加
i will publish soon a video
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, can you link me in here when you have please?
さんによる
I changed the lcd huawei p smart
But its not giving display
Its just vibrating
さんによる
コメントを追加
Wish I saw this earlier… but for future reference if it may help anyone; Huawei offers a free screen replacement within the first 3month of purchase.
http://consumer.huawei.com/minisite/nz/v...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How much will it cost for my screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How much to repair LCD and Screen repair for P Smart 2019
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
you will spend about 35$US
さんによる
コメントを追加
回答を追加する
john wilcox さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 23,391
