メインコンテンツにスキップ
2017年のHuaweiより発売された最新モデルのスマートフォンです。2017年3月に発売されました。ユニボディケースと Leicaと共同開発したデュアルリアカメラが特長です。容量オプションは32/64 GBで、6色のカラーバリエーションがあります。モデル番号はVTR-L09, VTR-L29, VTR-AL00、VTR-TL00.。
48回答 すべてを表示
Fingerprint sensor is overheating
Hello. I own a Huawei p10 and recently it fell out of my pocket and landed on its screen. Luckily it had its cover on and got a scratch on the upper left corner. Everything seems to be working fine until later on the day I noticed that the fingerprint sensor (glass) was unusually hot. I didn't notice it before but are finger print sensors warm to touch? Also the finger print sensor is working fine, it responds as default and a also enrolled a new fingerprint ID just to see if it's working, and it did. So anyone can tell me it will be okay or am I just worrying too much? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
3 件のコメント
I have this problem too.
This problem showed 3-4 days ago.
Fingerprint senosr area i very hot when i just use my phone normaly.
I instal CPU-Z and my soc_thermal was 52C.
Do you fix a problem?
さんによる
The fingerprint sensor is still hot but it hasn't affected my phones performance. I am still using it normally and I don't think opening the phone right now would be a good option.
さんによる
I am in the same situation,. The fingerprint sensor is burning hot after a sudden fall. Luckily no scratches in the front screen. But the sensor has a bit in the mid back portion. Service centers are more than miles away from our province. Already restarted but the fingerprint sensor is not working it just work for on and of now. Hope it won't cause anymore trouble.
さんによる
コメントを追加
2件の回答
最も参考になった回答
I say don't worry.
Others might disagree
I know on iPhones the Fingerprint sensor is directly above the charging port so the charging port is overheating,
In your case (I don't know where the sensor is to be fair), try rebooting it, and see if no other component is causing the overheating.
If it gets worse over time, replace the component that causes the overheating,
or take it to a repair shop.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you :)
さんによる
コメントを追加
My phone also fell out of my poket and the screen was slightly cracked, fingerprint scanner didn’t work anymore but mostly, the area of the sensor got very hot.
While the phone was still very much usable, except for the fingerprints, the battery life was very short due to the constant heating. It would not even last a day on a full charge while not being used much.
I brought the phone to a repair center where they swapped the whole display assembly. (glass, LCD, fingerprint sensor) Now it works perfectly fine again and the battery life is also good (~2days).
I hope this helps
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Is the fingerprint sensor still hot/warm to touch after the replacement? Thank you for the response.
さんによる
But the phone is that still under warranty? Because currently I have faced same problem and already reboot the phone so many times and even reset the factory set.
さんによる
コメントを追加
回答を追加する
ali arif さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 10
過去 30 日: 25
今までの合計 12,427
