メインコンテンツにスキップ
Guides and repair information for Ninja blenders.
128回答 すべてを表示
I actually have a Nutri Ninja Auto-iQ BL481-70 and need the base gear
The inside rubber part of the blender that's connected to the base not the blade (not sure what it's called) came loose and won't screw back on. It appears the treading is worn out. So far, I've only been able to find the rubber gear that you connect to the blade only. Any ideas?
Update (04/24/2018)
Sorry about the photos. I've provided some more that should be clearer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Marion Bee your image is a bit hard to see. If it is the external thread on the rotor it will be difficult to repair that but it's possible by rethreading it. Your image looks like part of the gear is still on the shaft. Take another picture of the gear (picture #2) but this one from the underside. It is possible that ll you have to do is to replace that gear. You must however remove the leftover part form the thread end of the rotor first. Again, it will help if you can post well lit clear images of those parts with your question.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Sorry about the photos. I've provided some more that should be clearer. I was thinking of replacing the gear but haven't been able to find it online. I've only been able to find the blade gear. Do you have any idea where I could find it?
さんによる
コメントを追加
回答を追加する
Marion Bee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 432
