メインコンテンツにスキップ
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 プロセッサ
254回答 すべてを表示
What size Hard Drive do I replace the existing one with.
Can you tell me what size or type of drive I need to replace what I have. That would be greatly appreciated.
If you could point me to a cheap one on Amazon the is around 256 GB that would be very helpful.
It would go into my 21.5" iMac that is around 2013 or 14.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Here are the specs for your Mac: https://everymac.com/systems/apple/imac/...
Given that you are looking for a "cheap" one on Amazon, I'm going to assume you are not looking to replace a Fusion Drive setup.
Essentially, you want a 2.5" drive with a SATA III 6 Gb/s connection. So you can search wherever you want for the best deal. I've provided a couple of examples below.
Cheap Option: For a regular 250GB HDD: https://www.amazon.com/250GB-Inchs-Drive...
Performance Option: If you want to spend a little more money for a 250GB SSD (recommended): https://www.amazon.com/dp/B0764WCXCV/ref...
Use this iFixit Repair Guide to help with the replacement: iMac Intel 21.5インチ EMC 2638 ハードドライブの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you are going to be opening up that computer it would be well worth it to replace the existing hard drive with a solid state drive! Just make sure you have all of the pieces to do so: SSD, and adhesive strips. https://smile.amazon.com/Crucial-MX500-2...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luke さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 163
