メインコンテンツにスキップ
Automobiles by General Motor's Pontiac brand. Pontiac was founded in 1926 and became defunct in 2010.
336回答 すべてを表示
97 Firebird fuel pump relayfuel pump not "on"
i have a 97 Pontiac Firebird base coupe. The other night out of nowhere, the car wouldn't start. New battery, 1/2 tank of gas, everything else good. A mechanic looked at it & found that fuel isn't getting to the engine & suspect the fuel pump relay. It seems too easy that this could be nothing more than a fuse & the whole time I'm pulling my hair out! What would cause the fuel pump to shut off & how do I "turn it back on"? This car is my baby & I desperately need to get it running. In addition, my kids have multiple health issues, so I really need my car! Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @blackandburned ,
Did the mechanic try a replacement relay to check that the relay was not the problem?
If not, here is an image showing the location of the fuel pump relay
(click on image to enlarge for better viewing).
Try temporarily replacing the relay with the same type (check info on relay) from the fuse block (select one that seems non-essential to the operation of the engine but not air bag relay though) to see if the car at least starts, to prove whether the relay is the problem or not.
If it still doesn't turn on then there may be a problem with the fuel pump itself, the wiring to the fuel pump, the PCM (powertrain control module) or the wiring from the PCM to the relay.
The PCM operates the relay which operates the pump.
An auto electrician is probably the best place to go, to locate where the problem lies.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Liz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 33
今までの合計 2,235
