メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
MBP cannot reach boot screen after trackpad replacement
A work colleague came across an issue with her MBP 15” Late 2011 where the trackpad completely gave up working and the keyboard behaved very strangely, some key presses may have registered, if they did they took a while to appear on screen.
I offered to take a look but didn’t have much time. I saw I could get a replacement trackpad cheaply so I ordered it and replaced the trackpad with the battery disconnected. The laptop had been asleep rather than fully shut down prior to the battery disconnection, I forgot it wasn’t shut down properly. I did the replacement over a few weeks with the bottom case removed and everything stored in a dry cupboard in that time. I’m not aware of anything happening to the laptop while it was in the cupboard.
After reassembly, I went to power it up. The sleep light lit up bright then went dim, fans started, hard drive spun up, but nothing else. No caps lock, no chime, and nothing on the screen. The fans progressively build up to full speed. I’ve let it sit like this for around 30 mins a few times and nothing happens. If I press and hold the power button to shut it down, then press it again to restart, it enters a boot loop of fanning up, spinning the hard drive then cutting it straight back out with a click and starting the same again over and over.
I’ve tried getting it going with the battery being connected and disconnected, with trackpad disconnected, new trackpad, old trackpad, keyboard disconnected, hard drive disconnected, 1 ram in, 2 ram in, no ram in, all key combinations at boot. Nothing makes a difference. I can’t do a PRAM reset, the system can’t get far enough to chime once. SMC reset does cut the power but doesn’t fix anything. I don’t have an OSX install disk to try and boot from but I don’t think it would boot from it anyway.
I’ve had a good look at the logic board and can’t see anything glaringly obvious, nor am I aware of anything happening to it. I don’t believe the machine was water damaged, but the logic board certainly exhibits all the signs that it has a problem. Hard drive contents are still intact after checking on another machine.
Can anyone suggest any steps to try? See a photo of logic board attached, I presume it will be requested. Please let me know if better quality is needed.
Any help would be appreciated, thanks.
James
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Disconnect the trackpad and see if it turns on might be a bad trackpad. If not, being this is a 2011, it needs to go in the land fill because it likely has a failing GPU lol.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
Thanks but definitely already tried. Tried without a trackpad, with new one, and with original. No change.
さんによる
I don't have much to add other than, as Brady said, it is very possible that the GPU is faulty, as was very common with the 2011 ones (although I'm not fully sure if the symptoms you're having are what would come from that), but friendly reminder to please not put these things in landfills everybody.
さんによる
Haha I was kidding definitely recycle it! But it's likely that it won't boot because the GPU is dead.
さんによる
I can’t understand how it could go from no GPU issues, have a trackpad issue, change trackpad, then have a useless GPU upon reassembly. Plus would it exhibit these exact symptoms? I would have thought the machine would boot up just with no video? Caps lock would work, chime would sound, PRAM reset would work?
さんによる
Yeah, those don't seem to be problems caused by the GPU, so I'm going to stop talking, 'cause I have nothing to contribute and am just going to mess things up. But actually, looking at your post, could it be possible that the computer got damaged from static electricity buildup while being left opened in a cupboard (this is probably unlikely)? Unless you already did this, I would also suggest trying to boot while holding down option, to see if it can make it as far as the boot loader (and maybe try booting into the recovery partition, if it has one), and seeing if it can display anything on an external monitor. Good luck.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
James さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 241
