メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
New display causing white flickering at top of screen
Hi,
I am replacing the display assembly on an iphone 6 plus. Everything works as normal however at startup the screen would often flicker and sometimes be unresponsive to touch. To be more accurate the flickering was a white lineor band that would rise and fall from the top of the screen and the display would become unresponsive or delayed..
The top flex cable connector to me feels loose compared to the origional.
Thx.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I would be sure this is a problem with the touch ic , not the screen .It is commonly known as touch disease. try lifting screen up while still on and connected and putting a fair amount of pressure on the main board (at the black area on shield below the screen connectors )with your thumb and see if the touchscreen responds while pressure is on.
if so then afraid you would need to have the touch ic replaced . It is expensive and requires micro soldering skill. Best left to professionals that have carried out this particular repair before .
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Totally agree.
さんによる
I should have mentioned when I put the original screen back on the problem goes away.
さんによる
You need to try another screen just in case. Sounds like a defective screen.
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 211
