メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
591回答 すべてを表示
2010 15" MacBook Pro logic board problem
My Mid 2010 15” MacBook Pro 2.4 GHz logic board is not working because of the NVIDIA GPU problem. I tested and confirmed that the graphics card gone bad and there are plenty of reviews online that tells about this problem.
I need help from the experts here to decide whether I can buy a 2011 logic board or at least replace this one with better one from the same year (i7 2.66 GHz from 2010).
Please let me know, which logic board is required to replace that can make my mac run again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
What do you mean by GPU failed? If it's kernel panicking, this is a fixable issue 99% of the time and is NOT the GPU. Also, if it is the GPU, do NOT replace with a 2011 or your life will be even more miserable lmao if all else fails and you want a unibody, buy a 2012 15" the only good one they ever made.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I am trying to replace the capacitor and fix it
さんによる
Good for you! Way to show initiative and try to fix the problem rather than replace the board blindly like some of the people on here recommend.
さんによる
コメントを追加
Hi
Reading your comments because I have an issue about the motherboard (at least is what I was told by the repair shop), any simple way that I can know where is the problem and how to solve it? Instead of looking for a new motherboard just as you wrote?
Thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adithya さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,205
