メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
428回答 すべてを表示
Xbox is not turning on anymore when I spilled a drink into the fan
So I spilled juice inside the Xbox fan vent and no it’s like dry and I didn’t take it apart and and dry it but it’s dry and all but every time I turn it on it turns on then turns off right away plz help for suggestions ASAP becuase I might need to acatyally just throw it away at this point and it’s only been a day so far since the inccident
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
You say you spilled juice in the fan vent? There are a few possible issues here.
1. Don't have any liquids in close enough proximity to any electronic device that you enjoy. Liquids and electronics simply don't mix well.
2. Since you spilled sticky stuff on the fan vent, it is possible that the sticky collected a ton of dust as it dried and now is clogging the air flow up, causing the device to overheat, thus shutting off before complete boot up.
3. Or, the sticky juice has caused a short somewhere. If this is the case, you might want to see if there is a professional who can run some diagnostics to find the issue. Then, price out the cost of replacement versus cost of repair.
I would check for excessive dust build up first as that is easiest to fix.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
mohamed harbi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,412
