メインコンテンツにスキップ
第三世代の Surface Pro タブレットは、2014年6月20日にリリース。
123回答 すべてを表示
How to change the backpanel?
Hi,
I bought a used Surface Pro 3 on Ebay.
On the Backpanel is a significant dent where (I think) the air grid is.
So I looked here to find a guide and the parts to change it, but saddly there is non.
Can some one possibly help me?
Regards
Jeff
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
It seems as though you have to completely dis-assemble the tablet to get to the back cover.
Here is a link to the ifixit Microsoft Surface Pro 3 Teardown guide, which may be of some help.
Here are some links to suppliers of the part.
It is not a recommendation to use either of them. It is shown to give an idea of the cost of the part. You may find other suppliers that suit you better. Just search for surface pro 3 housing back cover part to get results.
https://www.ebay.com/itm/OEM-MICROSOFT-S...
https://www.ebay.com/itm/Microsoft-Surfa...
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thanks for your answer. It was my fear that I would have to take it al apart. Don't know if it is worth the risk, with the screen being this easy to break...
さんによる
Hi,
If it's not causing any problems, it may be better to live with it as it is than to risk damaging the screen (plus the additional cost).
Cheers.
さんによる
I'm thinking the same thing. Have to wait and see if it works properly
さんによる
コメントを追加
回答を追加する
jeffcampana さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 49
